Suggestion: rewrite engine for 64 bit
Newbie Brad
Unread post by Newbie Brad » 12 Oct 2007, 16:08
I know this is probably a lot of work. But Usine might benefit with 64 bit operation on the new laptops.
Unread post by senso » 12 Oct 2007, 19:21
Actually Usine has a 32bit engine and in some parts (like audio filters) 64 bits.
My opinion is that 32bit is really enough for most audio applications and will always cost half than 64bits in CPU, memory access, etc...
Isn't it only a matter of marketing?
who use 192KHz/64bit?
Newbie Brad
Unread post by Newbie Brad » 12 Oct 2007, 22:14
I'm not smart enough to know. I just like if there is a computer capability then exploit it with the software if it will increase ability to do work. I see Reaper is 64 bit engine and admire; it seems most efficient.
Users browsing this forum: No registered users and 429 guests
