I like using selectors for my audio routing.
The only problem is that not only do I want to use the Audio Mix Dispatch as
Channel(s) Input-switched-to-output
I always seem to need Multi-Input to Stereo Selector.
I know you can use the Mixer to do so, but in this case then you have to control by array, and you only get mono in/out and have to use several.
I think it would be a good idea to have a reverse of the Audio Mix Dispatch, and have an Audio Mix Selector as well
-s
Audio Mix Selector (similar to Audio Mix Dispatch)
the audio selector is no more no less than the audio-mix-cross-fade module!
You are Right!!!
I keep forgetting!
I get used to using the Dispatch/Select on the Data so when I do some audio routing
I always get confused with this.
Thanks for the reminder..
-s
I keep forgetting!
-s
So the one question though, is there anything that takes Multiple Stereo or Channel Pairs and outputs in a Stereo Pair?
The Audio Mixer does, but only outputs a single output.
-s
-s
I'll try to implement a multi channels version.
Users browsing this forum: No registered users and 110 guests
