Record Video Out
thomaschamotte
Unread post by thomaschamotte » 02 Nov 2017, 08:24
Hello Evryyone,
How can we do to record an Output Video Device in usine ?
Can we must use VLC or something ?
sephult
Unread post by sephult » 02 Nov 2017, 09:06
Morning !
I haven't checked the video updates in a while....but
There was an input stream that had became available in HH3, but the output stream was not there yet.
I went through the same questioning and request...
I wanted to VLC and do some streaming as well....would be soo great!
As far as I know...no.
+1 and another +1 for you to move to suggestions :)
-s
thomaschamotte
Unread post by thomaschamotte » 02 Nov 2017, 16:11
What do you mean with an input stream ?
x.iso
Unread post by x.iso » 02 Nov 2017, 16:51
thomaschamotte wrote:What do you mean with an input stream ?
you can capture webcam or other video device feed into Usine, but you can't record video out. if you could, then it would be done by dragging video out device to record panel, like you do with racks and sound outputs.
thomaschamotte
Unread post by thomaschamotte » 02 Nov 2017, 16:51
Ho yeah, the Player IP.
It must be a way make it works ...
sephult
Unread post by sephult » 03 Nov 2017, 17:41
Yeah the IP Player was introduced, I too was asking senso about the need for an IP Output. Unfortunately it was only a stream input to Usine.
The output stream has not been introduced yet. (At least as far as I know)
Blaakk
Unread post by Blaakk » 27 Dec 2017, 03:03
Hey guys, OBS (Open Broadcasting Software) does a pretty good job of streaming and/or recording full resolution windows, displays, external streams, and lots of other stuffs. Very useful software.
