I find this error when i load presets to my patch.
Do you what can i do ?
Thanks.
It is currently 19 May 2026, 18:39
Unread post by thomaschamotte » 27 Oct 2017, 18:54
Unread post by senso » 28 Oct 2017, 22:27
Unread post by thomaschamotte » 29 Oct 2017, 00:26
Thank you.senso wrote:It's a bug, solved in the 3.0.145
actually, this command doesn't work on an empty preset panel. Just create at least one preset, then you'll be able to load a file.
or wait few days until the new release.
Return to “General discussion”
Users browsing this forum: No registered users and 202 guests
