I think the following improvements to preset fades in the grid could be very useful:
1. Allow modifying the format for fade times (particularly, to bars), just like you can modify the format for grid units.
2. set the maximum fade time to be the length of the section, rather than 1000s
3. in the grid, accurately depict the fade as a proportion of the segment (rather than an arbitrary triangle)
I'm really enjoying sequencing presets in the grid, and I believe any of these would be a big improvement to that kind of workflow. All three would help the user know how much of the grid section is being devoted to a fade-in.
Cheers,
Brian
improvements for preset fades
- senso
hi,
1) should be possible, I'll take a look.
2) humm, not sure : if we have a 1 bar section in loop and a 1 min fade in ?
3) same than above
3) same than above
