Patch Edit - Zoom!
sephult
Unread post by sephult » 17 Oct 2017, 12:37
I know this is probably far off...but you know whenever I patch depending on my resolution as well...it's hard for me to see and wire nodes.
It would be totally cool to be able to zoom the patch edit/module window just like a user interface zoom!
-s
Unread post by 23fx23 » 17 Oct 2017, 13:21
agree ;) in big 'towns' zooming out could help too
x.iso
Unread post by x.iso » 17 Oct 2017, 14:02
+1!
Also click and drag to select multiple modules or wires. even better: shift+click and drag to select modules and ctrl+click and drag to select wires.
Unread post by nay-seven » 17 Oct 2017, 14:39
For info, Shift+ click and drag to select multiple modules is already implemented ;-)
x.iso
Unread post by x.iso » 17 Oct 2017, 19:48
oh wow, I thought I already did try it. there's nothing about it in the corresponding manual section. is there perhaps a separate section with all those contextual shift-click and similar actions?
Unread post by senso » 28 Oct 2017, 20:24
ok, zoom will be available in the patch editor.
v 3.0.145
Unread post by 23fx23 » 28 Oct 2017, 21:11
oO amazing!
