fading between vst/au plugin presets
bgracie
Unread post by bgracie » 06 Oct 2017, 22:49
What is the recommended way to fade between plugin presets like in this video?
http://nay-seven.com/beta/aalto_in_Usine.wmv
At the moment I'm using the following method, but it's pretty clunky:
- hook up all my plugin parameters to faders + pass if changed
- exclude the plugin itself from being saved as presets (otherwise, there is competing preset recall when fades are programmed)
-> so if, I change anything in the plugin interface, it gets bounced to the fader and stored in the patch preset
Is there an easier way?
Thanks!
Unread post by nay-seven » 07 Oct 2017, 00:00
hello and welcome Bgracie,
you found an old video here ! ;-)
one way is to create a display array module from the params outlets of your plug-in ( audio engine must be on)
and link this array to the input of the plug-in to obtain something like this:
Now use the preset manager of your patch to create presets and drag them to the grid and set fade duration for them
bgracie
Unread post by bgracie » 10 Oct 2017, 01:09
thanks, Nay!
