What is the reset command in HH3?
ahonoe
Unread post by ahonoe » 14 Sep 2017, 00:09
Hi. I noticed a new property on some modules called, "can be reset". From the HH3 manual I see that this can be triggered by the "reset command". Where is this command?
Regards,
Scott
Unread post by 23fx23 » 14 Sep 2017, 01:02
if an ui item got this fonction enabled, there usually is a little arrow on the toolbar (if displayed in item layout properties), or also a reset button on the menu, both will trigg a reset procedure of said module
Unread post by SylvainT » 14 Sep 2017, 11:12
Hello Scott,
The reset command is in the Usine Patch Settings module. You can have a command for resetting a whole patch. You can choose on each module of the patch if it can be reseted with the patch (and you can choose its reset value). Very usefull if you have a lot of control on a patch, total reset instantaneously.
Same thing with the random possibility...
ahonoe
Unread post by ahonoe » 16 Sep 2017, 22:04
Thanks SylvainT and 23fx23, What I'm looking to understand is how to send a reset command. Is there a "reset" module, or an IML command?
Regards,
Scott
Unread post by nay-seven » 16 Sep 2017, 22:42
many modules have a reset inlet ?
ahonoe
Unread post by ahonoe » 16 Sep 2017, 22:55
Thanks, nay. So no global, "reset all" command?
Regards,
Scott
Users browsing this forum: No registered users and 49 guests
