I think i have a bug in a sub Patch.
I can't pull a strink, add a module, move a modul... i can't do anything.
It's happened in a Groove Physic -> patch -> sub patch 2,3,4,5,6,7,8
The 1 is ok.
Is it a real bug ?
Thanks.
Bug in a Subpatch
No, this is not a bug but a polyphonic sup patch, you make the change in the voice 1, then you use the apply the polyphony button to apply your change to all the voices,
check about sub patch. in the manual.
thomaschamotte
Thank Younay-seven wrote:No, this is not a bug but a polyphonic sup patch, you make the change in the voice 1, then you use the apply the polyphony button to apply your change to all the voices,
