Stream video to network?
gurulogic
Unread post by gurulogic » 08 Aug 2017, 19:15
As a workaround to patch sharing between computers not remotely showing VU meters etc, I had a thought that I could stream the bitmap out of a container to view VU meters and other relevant info on stage but I'm not sure this is actually possible?
Any ideas? My network is working, patch sharing and tightvnc are running fine but I do not see how to send a video flow to the network.
sephult
Unread post by sephult » 08 Aug 2017, 21:52
No Video Network Flow output at this time.
I have already requested from Senso awhile back, as you can receive a stream, but cannot send one.
Hopeful this will get implemented sometime, I've always wanted to stream out and record/present externally.
-s
gurulogic
Unread post by gurulogic » 08 Aug 2017, 22:38
Ok, thanks. Back to plan C, sendng dB values via OSC and using faders as VU meters on the remote computer. Unless there is a better way?
