Harmor and the Disappearing MIDI input
estrauss69
- New member
I recently started using HH3 and for the most part, everything is working as expected -except for one thing. When I use IL's Harmor synth as a vst plugin, it works in the initial patch but when I re-open HH3 later and reload the saved work space, the plugin will no longer accept a midi signal. As a test I reduced my setup to a very simple state with just the MIDI Big Keyboard patch and the vst. After reloading HH3, Harmor will play if I use the keyboard included with the plugin but it no longer accepts midi from it's input on the patch block. Does anyone have any information about an incompatibility like this?
- nay-seven
Which version to do use , win 32/64, Mac ?
estrauss69
- New member
I am using Windows 7 64 bit. I have tried both the 64 and 32 bit versions of Usine with the 64 and 32 bit versions of Harmor on both my desktop computer and the laptop I use to perform with.
Thanks.
Thanks.
- nay-seven
Ok, so i test the 64 bits demo version in HH3 164 64bits and all works fine here, i test a patch with Big keyboard, a piano roll and 2 Midi devices ( a launchpad mini and a K- Board) , save the workspace, reload, ok, quit Usine and back, ok...?
sephult
Hi estrauss69,
Another thing I think might be an interesting clue is possibly how you do get it to work then after it is broken.
Do you create another workspace and put in the Harmor/MIDI Big Key? Do you just do another patch and plugin and it works in the same workspace as the broken one (one rack broken, the other working)? Interesting if then two instances will break after being saved. Then maybe a patch or work space upload should be in order at that point for comparison.
That might give some clues? It's a shot...but you know my mind hasn't had enough coffee yet and still sputtering ...so I'll see if I can assist too sometime today.
-s
-s
estrauss69
- New member
Just to be clear, I am using the 64 bit VST plugin of Harmor (v1.3) in HH3 not the stand-alone mini host (v1.6). If I output midi from HH3 as a controller it works fine. It's only when I try to use the Harmor VST inside HH3 that I have the problem.
When I re-open the saved work space, Harmor won't accept midi. If I delete the VST from the patch and add a new instance it works. If I save the working patch and try to reload it into an empty work space or the second rack of a work space with a working patch in rack one, it doesn't work either.
I've uploaded the basic work space I'm using.
http://www.sensomusic.com/forums/upload ... st%201.wkp
Thanks for your input.
E.
E.
- nay-seven
yes, it is how i've tested too, and works fine, saving wkp, patch, reload, your workspace works too..I am using the 64 bit VST plugin of Harmor (v1.3) in HH3
strange
estrauss69
- New member
Just as a test, I tried using Hollyhock 2 with Harmor and that worked fine.
Does Usine use Java?
- nay-seven
no java here, and as said works here in HH3 64bits/win Seven
maybe someone else can confirm ? have you try the devs ?
