I was just thinking it would be pretty cool...
When you add a new rack, it could ask if you want LEFT OR RIGHT.
If you select right, obviously the rack placement would start far right with space in-between.
It could populate the right side to left but can maintain space from the normal left racks.
I always want return tracks, but want them separated from source tracks.
Or have an additional work space attached and able to gap the audio.
Then returns or other buses can be separated on a different page.
-s
Rack Layout -Positions
hummm,
very hard to implement different layouts for the rack in the actual version of Usine.
I have to rewrite totally the workspace rack management.
so not sure...
so not sure...
hahaha,
I know I was shooting out into space with this one HH6?
Maybe by then I can pick up on the programming and help do.
I like the Additional Workspace, I am going to have to look into more because I do not use it as often as I want.
Maybe instead of rack management modifications.....some sort of cross-workspace rack scheme?
I would definitely use the additional workspace as my Return/Send for Effects and Busses, while my Main page for instrumentation.
I know still a far out suggestion, however would this be a better path to pursue rather than modifying the rack-management?
I assumed since the Additional workspace was already pursued this path would generally be easier for modification.
-s
-s
I'm more thinking about a way to have an unlimited number of wkp opened at the same time and manage a global layout.
Alright Checkmate!
I'm on board.
-s
I'm on board.
-s
Users browsing this forum: No registered users and 36 guests
