I think there needs to be a button to clear the preset list.
Even if it prompted are you sure, I think that is fine.
I end up filling a list up and wanting to do a different way...I cant find a way to clear out.
Any methods I missed?
-s
Preset List - Clear All
there is already a 'clear all' command in the menu ?
YES!
So the problem is that accessing this command menu is difficult. I had to click in the empty gray space in the bottom right of the presets panel to access this.
I was trying to access from the LIST view and could not find anything. Also clicking other buttons in the Preset List did not prompt the Command Menu to show...only the gray space.
Maybe a Command Show button is needed? Or update so that any option in the Preset Panel shows the Command Menu?
-s
-s
in the next release it will be more accessible.
