"hidden string" is dangerous !
Unread post by sm_jamieson » 14 Jul 2017, 12:48
The Usine "hidden strings" are rather dangerous if you do much text input in Usine.
If I type "quit" into a text box for some reason, fine.
If I forget to put the focus on the text box, then Usine exits without saving.
This is ridiculous and very dangerous, probably more dangerous than useful.
Nowhere in HH2 or HH3 can the hidden strings be switched off (not even in the Protect settings).
Please can we have a method of switching these off ? (in Protect, in Learn, etc).
They are a liability !
Simon.
sephult
Unread post by sephult » 14 Jul 2017, 13:05
I agree,
You would want this to be enabled/disabled in the Protect section I believe, or an enable in expert.
-s
Unread post by sm_jamieson » 14 Jul 2017, 14:26
I really don't mind where the settings goes - wherever Senso / developers think it is best.
And I don't know if others would prefer to have an extra control over the instant "no save" QUIT command.
But from my point of view I would like to disable the hidden strings completely, and the default to be OFF !
Simon.
Unread post by senso » 20 Sep 2017, 10:41
ok, I'll implement an option :
setup/expert/'enable hidden keys'
but it will be ON by default.
