Midi Clock from Usine to MicroGranny 2
thomaschamotte
Unread post by thomaschamotte » 14 Jul 2017, 00:35
Hi Everyone,
I'm using a monophonic granular sampler MicroGranny.
You can see the manuel PDF to this link if you want to understand the Machine : http://www.bastl-instruments.com/instru ... crogranny/
By the way,
I Use an audio interface Komplete 6 Native Instrument.
I use the Output Midi of the Komplete 6 to come to the Input of the Sampler MicroGranny.
I want to synchronize the Sampler with the clock of usine.
Can you help me to do it ?
Thanks.
Unread post by nay-seven » 14 Jul 2017, 14:43
what i read this about synchronization:
MIDI SYNCHRONISATION
microGranny can synchronize the GRAIN SIZE and END position (and
looping in general) to MIDI Clock. When it receives the clock message
it turns automatically to slave. You can turn off the synchronisation of
individual sounds by turning off the SYNC parameter. When in sync
mode, the settings GRAIN SIZE or END are indicated on the display as
multiple or division of one beat. This means that if the GRAIN SIZE is set to
1 the GRAIN is one beat long (24 MIDI clocks).
So you can use MIDI sysex editor module or the MIDI create message module who also has timing clock and start , stop, continue message possibilities. Now you need to ask their support which exact message this sampler is waiting for
Users browsing this forum: No registered users and 533 guests
