Hi everyone, I want to use the volca fm along usine but the little one does not recognize midi program change.
So, I had the idea to make a patch that will send entire patches via sysex which will basically achieve something similar.
I used the sysex module, but I did not manage to get anything really working.
The idea was to use dexed vst to generate the sysex message, store it in the sysex module and send it to midi out when needed.
My first problem is to store and visualize the message in the module I do not know how to patch the two.
Any hints ?
Thanks a lot.
Sysex sorage and recall for volca fm.
Your output MIDI Device does not default to wire SYSEX to the output.
Double-click the device either in the rack output or device menu. You will see the two red nodes and no wire.
Wire those up and try.
-s
-s
