Duplicate Grid Section
lytz1
Unread post by lytz1 » 04 Jul 2017, 23:48
Should be a quick and easy thing. It's not even necessary to have "copy/paste section",
but a simple "duplicate" command would be indeed *very* helpful, especially as we can now
add quite a lot of stuff into a section.
To manually recreate additional sections with the same content (multiple patches dragged into a section for example)
for multiple sections is quite time-consuming and cumbersome.
Thanks for consideration,
best,
tL.
sephult
Unread post by sephult » 05 Jul 2017, 03:34
I do have to agree on this one, I think I might have mentioned before and you are right it does become cumbersome.
The section copy is cool...but as you build...you spend a lot of time then deleting what you don't want.
Also when you avoid the section duplicate...obviously every part then is a drag and drop rack-to-grid.
Like one extreme or the other.
Do you mean like a duplicate keyboard shortcut key lytz?
or obviously a command button, which could have a shotcut key....lol
I do like and think it is needed as well. Good suggestion.
-s
lytz1
Unread post by lytz1 » 05 Jul 2017, 11:58
Hmm, not even something that fancy. ;)
I would just suggest another menu entry where "add section/insert section/delete section/etc" is located.
That would be good enough.
Best,
tL.
sephult
Unread post by sephult » 05 Jul 2017, 12:12
Yes I agree, that's what I was going for....obviously one can bind whatever key shortcut they want.
Regardless you are correct.
-s
Unread post by senso » 20 Sep 2017, 10:35
I'll try to implement a duplicate section command.
