External audio editor setup?
Stanevie
Unread post by Stanevie » 01 Jul 2017, 06:44
hello
I am having problems setting up an external audio editor (izotope rx4 and/or melodyne 4) in hollyhock 3.0.132 .
In the "set up" panel I go to the "global" tab and then under "external editors" I click on [wave editor].
I then select Macintosh hd>Applications>Izotope RX .
"Izotope RX.app" shows up next to "[wave editor]" .
I open a "File Collection Panel" of a sampler, click a wav file, then click the "edit file" button and nothing happens (should anything happen?).
I tried restarting hollyhock.
Any ideas?
I am using a mac osx 10.9.5 .
thanks
phil
Unread post by nay-seven » 03 Jul 2017, 12:04
Thanks for your feedback, you're right, was a bug, solved in next version 134
Stanevie
Unread post by Stanevie » 03 Jul 2017, 13:53
thanks for the fast response nay-seven.
works perfectly for rx4 and melodyne 4!
having a great time with hollyhock 3.
Thanks again to all those involved.
phil
