How to record the video output?
matze
Unread post by matze » 28 Jun 2017, 18:33
Hi there,
HH3 seems not to be able to record the Video Output Signal. Can you give me a good advice how to capture the Video Out Signal synchron together with the Stereo Out Signal in a good quality (Windows7 64bit) ?
Thank you,
Matze
sephult
Unread post by sephult » 28 Jun 2017, 21:50
I'm not for sure if this is really available at this time. I had discussed this as well before. There is an input IP stream for the video. If an output IP stream was introduced then you could stream out to something like VLC or another external recorder. Hopefully sometime this will be available?
-s
Users browsing this forum: No registered users and 116 guests
