Helllo Olivier an Usiners,
a suggestion: A mute and solo button on the master section (each output could have its mute an solo button), il well be very fine.
A bug ?
The sequencer midi file player (in template, sequencer files) has not possibility to switch between differents midi files in the menu, buttons 1 to 8 are innactifs. Is it a bug or different mode operation than Piano roll module.
Franck
Another future request and can be a bug ?
- senso
thanks for feedbacks
But it can easily created in the insert parch?
I'll take a look
Actually there is no room on the master section to create mute/solo btn.franck wrote:a suggestion: A mute and solo button on the master section (each output could have its mute an solo button), il well be very fine.
It's not a bug, in the seq-midi module only one midi file is available; maybe not so clear.A bug ?
I'll take a look
franck
Hello Olivier,
I know it is possible to create a patch for "muting" an "soloing" each master out but i could be more esay and mode visual if each output has its buttons (with the top or with the lower part of vu meters).
I think it was so clear if it is the same midi sequencer in the 2 versions.
Franck
Franck
