chance of FX triggered every 8th notes but needs to stay on 1 Beat
lytz1
Unread post by lytz1 » 03 Jun 2017, 02:02
Hey guys,
following scenario:
I work on an effect that calculates the probability of getting triggered randomly on every 8th note.
So far so good. Easy.
But here's the thing: When triggered, I need the effect to stay ON a whole beat after the trigger.
(so that the time/length of the triggered FX is always constant, despite
having a random chance to get triggered every 8th note. I hope this makes sense.)
How do I accomplish that?
tL.
Unread post by 23fx23 » 03 Jun 2017, 14:03
one of the solutions can be to use the count ms module in /time (you can convert 1/8 to ms using tempo to delay module)
then each time your effect is trigged it starts the counter, wich will count 1/8 then the out pin 'counting' will go back to 0.
lytz1
Unread post by lytz1 » 03 Jun 2017, 15:38
Ah yes, I see. Thanks a lot.
If I might have any problems I'll come back to you but I think this should be pretty straightforward.
Thanks again,
tL.
Unread post by oli_lab » 03 Jun 2017, 20:27
you could also make good use of 0 to 1 an 1 to 0 modules as well as the set and reset inputs on a switch.
lytz1
Unread post by lytz1 » 03 Jun 2017, 22:18
Ah alright, thanks a lot!
Users browsing this forum: No registered users and 129 guests
