I have re-installed Usine latest vs on my macbook with sierra. It opens and when the language popup shows I select english and then another instance of Usine with the language popup choice opens, elect english again and then opens another instance ....neverending loop!!!!!
Help.
By the way, it's very quite here at a sensomusic. I'm worried. Is Sensomusic still healthy?
huge problem with re-installing usine on sierra
thomaschamotte
i have also a problem with a re-installing Usine on sierra.
when i try to install i have a crash problem. Usine can't open.
I tried to pass in the packet folder of the app,
Content -> Macos -> Usine(terminal opening)
And it worked. I have importe the old setup from my old Usine
But When i restart i had the same shut down problem and i can't use new Usine
Does anybody meet the same problem ?
Hello, the forums are not always the best place to get help if you are having technical issues with Usine. I suggest emailing your problem to contact@sensomusic.com if you have a problem with installation or running of the program that needs prompt resolution.
Sorry, seems the rss flux is down so i don't receive new posts notifications
With sierra its a folder and writing rights question, generally, unzip on the desktop will solve the issue
Users browsing this forum: No registered users and 106 guests
