Hello everybody,
I'm using two loopers RC51 in my work. One for the bass and the other one for a synthesizer.
In the beginning of my work, I'm in a free loop. Because it's a free expression between the bass and the organ.
I would like to synchronize both looper between them but not with the grid.
Do you know how i can do ?
Thanks.
Synchro between loopers
you could detect witch loop is the longest and retrig it when the shortest loop restart.
thomaschamotte
Yes it is a good idea.
I do it.
I do it.
thomaschamotte
Ok !
It works !
For the community and i.
My configuration.
Two Looper RC51 and the Grid.
One for the bass the other for the synthé.
One seq of the grid for the looper bass and the second for synthé and the bass.
Everything on free-loop.
4/4 rythm but for the next part of the song Usine on 2/4.
Two 4/4 for the bass and
Four 4/4 for the synthé
I put a trigger on the Re-starting matser sampler of the synthe looper. And the Out trigger to a Bus.
I put the bus to the play area of the Master sampler of the looper bass.
And that's it.
It works very well.
Thanks.
It works !
My configuration.
And that's it.
It works very well.
Thanks.
good on you !
Users browsing this forum: Google [Bot] and 86 guests
