Configure OSC Iphone
Unread post by cmodica » 26 Feb 2017, 15:42
I bought TouchOSC and i try to configure the network between my Iphone and Hollyhock. I am not at home and i haven't any internet connexion. Exept with the 4g of the IPhone.
I can't find a way to send OSC messages from the TouchOSC on the Iphone to Hollyhock !
Did somewone could help me, please ?
dmitriyc
Unread post by dmitriyc » 26 Feb 2017, 16:34
With OSC, there is usually an address associated with the broadcasting via UDP. Usine listens to port 8001 by default. Some OSC programs wont let you chane the port, so you need to change Usine's listening port in the network settings tab OR if you have the option, change the OSC broadcast to port 8001. Its best if you use an OSC lister module. From then it should be cake.
Unread post by cmodica » 26 Feb 2017, 17:22
I try but it seems not working !!! :(
I realy don't understand how it work.
And when Usine OSC is active, everything is very slow ... When i click on something i had to wait 3 ou 4 sec before something happens !!
This a picture of my trying
dmitriyc
Unread post by dmitriyc » 26 Feb 2017, 19:06
Just for reference, how old is this macbook pro?
dmitriyc
Unread post by dmitriyc » 26 Feb 2017, 19:09
So in the module menu, if you do a search for the "osc lister" module, you can actually start catching data from your phone using that module. This is the best way to know if you are broadcasting properly. Also i see that you are accepting port 8002 in Usine. It is very important to broadcast to 8002 from your phone to actually get a connection going.
Unread post by nay-seven » 26 Feb 2017, 19:20
OSC works with a WIFI connection, as you see your computer don't have any IP address, so no way
Unread post by cmodica » 26 Feb 2017, 21:51
OK. I understand !
I will build a Ad-Hoc wifi network .
I think it should be work.
did it ?
Unread post by cmodica » 27 Feb 2017, 13:37
I am in the train, back home and i try to connect Usine and my Iphone to work with TouchOSC.
So, i create un new network on my Mac. I name it, CM-AD-HOC.
I have an IP adress on the Macbook Pro something like 169.254.196.99
I have an IP adress on the IPhone. Somethink like 169.254.196.122
The two devices seems to be connected.
But hollyhock seems not receive any IP Adress. In the network Setup i can read the Host Hame : PRO-DE-CHRISTOPHE.LOCAL
But the IP Adress is still empty ???? :rolleyes:
Why ? Someone have an idea ?
Unread post by cmodica » 28 Feb 2017, 09:52
Now i am at home.
I am connected to the internet. But No IP adress in Hollyhock !!!
There is no fireWall.
What is happening ?
joffo78
Unread post by joffo78 » 28 Feb 2017, 10:21
Hello . Did you try to disable your 3G connection before making your wifi connection ?
Unread post by nay-seven » 28 Feb 2017, 11:01
Can you also try from a fresh unzip Usine version ?
Unread post by cmodica » 28 Feb 2017, 19:02
I try to answer to your questions.
1 - dmitriyck, my Mac book Pro is a retina mi-2012 model
2 - Joffo78, no, i didn't try to disable 3G or 4G. But the problem is the same at home with the sfrBox...
3 - Nayseven, i have been dowloading and install Usine from a fresh unzip version. The 2.0.090.
But it don't solve my problem. When i active OSC in the setup, i can read the Host Name, but there is no IP Adress.
The macbook is connected to the internet and i can read the Ip Adress in the preference system panel of the computer.
It make me crasy !! :rolleyes:
joffo78
Unread post by joffo78 » 01 Mar 2017, 00:37
Try to disable it. Sometimes it could make a conflic with ip adress
Unread post by cmodica » 01 Mar 2017, 08:05
Thank you. I will try.
But even when the iphone is shut down i can't read any IpAdress in Usine.
I tried, and it doesn't solve the problem.
:mad:
Unread post by cmodica » 02 Mar 2017, 09:42
I find a solution.
I don't kwon why, but i need to run the "TouchOSC Bridge" on Mac OS 10.12.3 to receive OSC Messages from TouchOSC in Usine.
TouchOSC Bridge should be downloaded on Hexler web site.
This software is only needed if you use Wifi Midi Messages. But,for OSC messages and Usine, with Mac OSX and Iphone, i need to run it.
Now it works fine.
Thank you all.
Unread post by nay-seven » 02 Mar 2017, 10:32
Ok a bit strange but good to know :)
and now you receive OSC but if you refresh MIDI devices and activate TouchOSC Bridge, you receive also MIDI messages ?
Unread post by cmodica » 02 Mar 2017, 10:38
YES ! :cool:
But it is more easy to send OSC mesages, from Usine to TouchOSC. Beacause the Motorised option in midi device didn't send midi feedback to the iphone.
It is cool !
kurtjoy
Unread post by kurtjoy » 24 May 2017, 09:25
The biggest issues I had was ensuring that the correct ports to listen to and receive from are set. I used 10000 to send and 9000 to receive using Lemur on android . Working in holyhock and reaktor
k
Users browsing this forum: No registered users and 389 guests
