Receive multiple output from arduino
BatKam
Unread post by BatKam » 17 Feb 2017, 10:07
I tried to look on the forum the answer but I haven't found it.
My issue is that I can receive one data from arduino into Usine but I can't manage to receive multiple datas. (I want to manage 16 datas from the arduino card, coming from analog sensor).
Does someone has a clue for this issue ?
Thanks in advance,
BatKam
Unread post by nay-seven » 19 Feb 2017, 10:22
can you give us a simple example of your ino file (2 or 3 inputs) and the Usine patch you use ?
BatKam
Unread post by BatKam » 23 Feb 2017, 15:03
I've done the communication bridge between arduino and Usine by using a max patch, sending datas via MIDI protocole and it works very well!
Users browsing this forum: No registered users and 28 guests
