Need some tips for a Midi Octave Sequencer.
lytz1
Unread post by lytz1 » 06 Feb 2017, 00:06
And another one I have a little bit trouble realizing.
I'd like to build a small Octave Sequencer, 5 Rows (+24,+12+,0,-12,-24)
and a variable number of steps (length) that transposes a Midi Sequence
in octaves in a sequenced fashion.
I am working on an array sequencer right now, but I have a bit trouble here.
Is this the best approach? Any hints on how I should tackle that patch?
Thanks in advance,
tL.
(Biggest issue is that I can't get the buttons "monophonic" - for lack of a better word.. :) I hope you guys know what I mean by that.)
sephult
Unread post by sephult » 06 Feb 2017, 11:52
So you using a step generator for octave jumping?
I actually have one if you would like to look at and taylor to your needs, or I can just walk you through some ideas.
-s
lytz1
Unread post by lytz1 » 06 Feb 2017, 19:29
Hey Seph',
Yes, exaclty, Step Generator for Octavejumping. Sure, I'd like to take a look at yours if I can.
Probably will explain everything in itself. Let me know. ;)
Best,
tL.
