Module search bar
dmitriyc
Unread post by dmitriyc » 24 Jan 2017, 00:29
It would be awesome if it was possible to enter a word and be able to search for this word through the modules and be able to replace the text found with another user selected word. For example if I have multiple buses is one module, when I duplicate, all I want is to change one word, but it would have to change a number of times. It would also be great if you could swap the text en masse as well as by step confirm. Thanks!
Unread post by senso » 07 Mar 2017, 18:25
it's a good suggestion but not so simple to implement.
I'll see in future versions how we could do that.
Users browsing this forum: No registered users and 67 guests
