Multiple simultaneous wiring per objects selected.
dmitriyc
Unread post by dmitriyc » 24 Jan 2017, 00:25
Just so many wire connections! Would love to select modules and drag all their wires at the same time. Thanks!
La Tenaille
Unread post by La Tenaille » 24 Jan 2017, 22:30
you can hold ctrl+shift while dragging.
dmitriyc
Unread post by dmitriyc » 25 Jan 2017, 01:00
Hmm...doesn't seem to work for me. I tried all combo buttons... is this an option to turn off or on somewhere? Just to clarify, Im recommending that if you shift+select modules and drag out a wire, multiple wires would come out of the selected modules simultaneously so I don't have to mess around with the position of the modules just to figure out if all patches have connected to a single point or not.
La Tenaille
Unread post by La Tenaille » 27 Jan 2017, 21:11
I don't think this function can be deactivated. I hold ctrl+shift and drag from a module pin to another and multiple wires are created. I don't know the limitations of this shortcut but to link let's say 8 audio audio matrix module out to 8 audio matrix audio in it works and creates 8 wires.
Users browsing this forum: No registered users and 77 guests
