I know that if you have an OSC bridging software you can get the myo to behave in hollyhock. I've had really good experience, however I wanted to know if anyone has any experience with the vibration feedback - if that is also sent through OSC and whether I can take advantage of it (trigger it).
Thanks!
Myo - vibration feedback
- nay-seven
What do you need an OSC Bridging software ? Usine can receive directly OSC messages ?
about the vibration, check the OSC lister module and see which address you receive, then try to send it back with an OSC send module on the same address ?
fractalist
@nay-seven : yes but myo doesnt really send osc, so you need that kinf of software.
unfortunately you can't control feeback vibration, to my knowledge, except if it has changed (and it is annoying to me)
dmitriyc
Just to follow up on my own question: I found that with MYO Scripts, you can program, amongst many other things, the feedback vibration.
http://developerblog.myo.com/getting-st ... ts-part-5/
This is page 5 of the series, I would suggest starting from part 1 and working your way.
