Enttec open dmx usb on MAC OSX with Usine
I'm having a big issue : I just bought an Enttec open dmx usb and it doesn't work in Usine. In the configuration pannel of the MAC, it recognizes it as FT232R USB UART. But Usine can't detect it...
Any suggestions ?
It would be so nice!
Thanks in advance
BatKam
Usine Hollyhock 84a, OSX 10.9.5
Any suggestions ?
Thanks in advance
BatKam
Enttec drivers issue. Solved by email answer
For those who encounter the same, check this Enttec page, they have a specific tool to update their drivers and solve this.
Hello, i have the same issue, but i can't find on the enttec website the tool you are talking about...
thanks!
H
thanks!
H
I strongly recommend the artnet DMX king series !
thanks for the recommandation! but i already have the enttec :-/
Oli LAb, why do you prefer the artnet DMX king series?
as it stil doesn't work with enttec, i might consider buying one...
thanks
thanks
I prefer Ethernet more than USB !hgermain wrote:Oli LAb, why do you prefer the artnet DMX king series?
thanks
with Artnet, your computer is connected on a LAN as is the DMXKing.
you can hot plug everything, if there is a loss of power every thing get recconected automatically.
Users browsing this forum: No registered users and 352 guests
