MIDI velocity and pressure
r.erorr
Unread post by r.erorr » 07 Jan 2017, 22:32
I want to get those two values separately. If my observation is correct it somehow appears as code2, but how to dispach(?) them. I'm also not sure, but probably first value of pressure could be velocity? Even if it is not true, that first value could be useful for me, but again what could be the best way I can get those two values fore each note separately
r.erorr
Unread post by r.erorr » 07 Jan 2017, 23:26
ok, never mind, I found a solution. Data2 pass only if msg is 144 and that's all.
Unread post by nay-seven » 07 Jan 2017, 23:29
yes, you can also use the midi filter module to separate notes and after touch
