Time information in the sequencer.
Unread post by bsork » 17 Sep 2007, 14:33
Would it be possible to display the start + length and/or end values for the patches in the sequencer? Also the position of the markers?
If these values also could be edited - that would be really great! If possible, changing the start value should keep the length and move the end like dragging the whole patch back and forth, while changing the length or end value would keep the start where it is, and change the other of the two values (ie new length -> change end, and vice versa).
With reference to my suggestion on how to treat button-clicks and markers in the ruler in the News forum, I would suggest that a left single-click on a marker would show the start value somewhere. Maybe beneath the grid list?
The values for the current patch could for example be shown to the left under the insert patch.
Unread post by senso » 17 Sep 2007, 18:23
Good suggestion,
I'll try find a simple way to do that, with a low CPU.
Unread post by bsork » 17 Sep 2007, 20:46
Nice!
