usine HH2 keyboard assignments
Unread post by sm_jamieson » 07 Dec 2016, 04:01
Does anyone know where the midi computer keyboard assignments are set for HH2 ?
Are the keyboard shortcuts documented anywhere ?
For example, spacebar switches on and off the audio engine. And sometimes the arrow keys seem to minimize and maximize racks.
I am using the keyboard input module to enter text to a patch, but I need to switch off the spacebar assignment or the audio engine is switched on/off when I enter a space !
Simon.
Unread post by nay-seven » 07 Dec 2016, 09:13
All shortcuts are in the user's manual
about the space bar, create a new midi or key learn to change it
Unread post by sm_jamieson » 08 Dec 2016, 04:45
OK thanks, that works.
Is there any way I can disable the UP and DOWN arrow keys that navigate between racks ?
There is no obvious button there to do a key learn on.
If I do a key learn on something else and assign an arrow key, then the arrow key does the new
action and still changes racks.
Even when you are on interface builder, the up/down still changes racks on the main screen, which is
hardly what you would want.
Simon.
