VST1 & VST2.4 & VST3 & VSTi Compatibility with Usine Hollyhock 2?????
SuggarBearr
Unread post by SuggarBearr » 29 Oct 2016, 19:54
Wassup my name is SuggarBearr and I wanted to know
If VST1 & VST2.4 & VST3 & VSTi were compatible with
Unread post by nay-seven » 30 Oct 2016, 09:56
Hello and welcome suggarbearr,
VSTt 1 are really old now, if you still have one, maybe will work but generally with no graphic interface, VST 2 and VSTi works with Usine, VST 3 not yet.
Remember Usine is a free download, so you can quickly know if your plug ins works
gurulogic
Unread post by gurulogic » 31 Oct 2016, 02:49
As an option for vst3 loading , if you use a wrapper / chainer such as Bluecat Patchwork in Usine, it is possible to load vst3 and more.
SuggarBearr
Unread post by SuggarBearr » 31 Oct 2016, 16:43
What about VST 2.4 will they work in Usine Hollyhock 2?????
Unread post by nay-seven » 31 Oct 2016, 17:01
Yes
SuggarBearr
Unread post by SuggarBearr » 31 Oct 2016, 18:07
Thanks Nay-Seven
SuggarBearr
Unread post by SuggarBearr » 16 Nov 2016, 11:08
One more question I got these effects that just say VST is the regular VST compatible????
