Three new add-ons
1) the masterpiece Groove Box made by Bsork
2) Modulated Frequency shifter FX. A small emulation of the great Hematohm plugin from Ohmforce.
3) X-Proto: The input sound is separated in 8 frequency bands.
Each band is triggered by a step sequencer.
New Add-ons
- senso
- senso
Hello Bsork,
In the X-pro add-on I have created a simple subpatch that generate a set of random steps according to a density parameter.
I think I can be a good idea to use it in your GrooveBox, to have a density parameter associated with your randomize buttons?
what do you think?
what do you think?
Not a bad idea at all! I'll look into - maybe during the weekend sometime.
I might do a set of (sub)patches that could be incorporated into the Groove Box idea, with various triggers of filters and stuff if there's any interest in that. Sort of a Lego Rhythm Box?
BTW - I really liked the FreqShifter! If only I could understand how to use the FFT modules myself. I tried to find some info on the net earlier today that would explain in lay-man's terms what "real part", "imaginary part" and "inverse FFT" mean, but no... So if you or anyone else know where to look, I would like to know! (Sorry if this is a bit OT.)
- senso
Another request, since your GrooveBox seems to be a reference for many "Usine students":
For me the names of the Buses (AUX1 L, AUX2 L) can create a confusion with the internal default Aux buses.
Don't you think that they could be renamed in FX1 send L, FX2 send R, etc?
I don't think you have to add add so much built-in effect, let users add their own effect, and keep the actual structure simple and very clear.
Ok, I'll rename the buses and add a trick or two to show what can be done with just a couple of extra modules, hopefully without making it confusing for noobs.
Oh yes - some comments as well.
Hm - hadn't imagined this thing to be used for anything else than the video.
