please, can you somehow improve wire selection?
that one selection dot in middle of the wire is.. hmm it works, but..
sometimes wires are crossing right in the middle so it is hard to select correct one wire
so i know that make wire clickable anywhere is hard to code (as you have to check every pixel of the wire if mouse is over it)
what comes to my head
- make another two select dots on wire near its begining and near its end (this one i like a little bit more)
- or based on mouse position move that one dot flowing on the wire
and nice to have
What about to make wires reppluagble?
- like when i grab one end of the wire it will disconnect that wire from in/outlet and you can replug it into different module (now you have to delete wire and make new one, which is little bit annoying), and when you not connect t he wire to another in/outlet the wire will be deleted.. this is how it works with wires in Tracktion racks, and makes the experience of repluging/deleting the wires really comfortable...
wire selection
1)you're right sometime hard to select wires. That's why in HH3 the middle dot will be movable, so it will be possible to change its position.
2)replaceable wires: somewhere in our huge todo list...
Users browsing this forum: No registered users and 5 guests
