hi,
I updated Komplete today, and Kontakt disapeared from the librairy/plugin. I "rescanned all", I indicated all the different places of plugin files and so on.
I opened Kontakt in Cubase, all is fine, but in Usine it fails. Reaktor works in Usine.
The error message is : "Error : "Kontakt 5 is missing at plugin location"
Usine version 2.0 084a OSX32
Kontakt 5.6.0
Is this problem occured to anyone ?
I'm a bit embarrased, I need Usine+Kontakt two days a week for job.
Thanks !
Gilles
Kontakt disapeared from librairy
Recently, Native seems to choose to support only 64 bits appz, (as for Reaktor 6) so I'm bit afraid they apply this to this kontakt update..I've ask on their forum but no answer yet.
You can try jbridge to run it
Thank you. I'm going to check with jbridge démo and uninstall this version of kontakt if it's a 64bits problem.
I tried jbridge it seems to be OK with the 0.94 version. I'm under OSX El Capitan, jbridge recommends 0.95b but it doesn't work. The 0.94 version is ok in demo mode. So I bought it.
--10 minutes later---
However, the jbridge software is not user friendly,
I saw your post on NI forum https://www.native-instruments.com/foru ... le.309091/ and read answers. Here is a second way to solve the problem :
- first, I connected to my Native Instrument account on the website
- went to the download page https://www.native-instruments.com/en/s ... ch=kontakt
- downloaded : Kontakt 5.5.2 Update - (OS X 10.9 or higher)
- re-installed Kontakt 5.5.2, and overwrited my 5.6.0 version of Kontakt
- Opened Usine and rescaned all plugins
- and that's ok !
I spent 10€ for jbridge, I'll be able to use whatever plugin with whatever host !
Thanks Nay7 for your support, problem solved in 20 hours !
- and that's ok !
ok, good news, and don't worry we still hope finding a native solution one day
I just ran into this problem, so thank you to glikbp for sharing this solution.
I certainly don't mind using 5.5.2 again, since you say it is working for you under El Capitan.
Users browsing this forum: Google [Bot] and 110 guests
