Counter sends a "1" value when it stops. How can I get a switch turn ON and stays ON when the counter stops?. It is similar to how to turn ON a switch with a button.
Thanks in advance
Miliseconds counter that activates a switch when stops counting
Either the toggle module, or the toggle input on a switch???
Actually, just feed the 'value' output of the counter directly into the switch value. It will be ON whenever there is a value & OFF whenever the counter is at 0. If you would like it reversed, use a not(a) module between the counter & the switch.
yes it is true but you'll need a "pass if changed" in between if you want to change the state of the switch by hand.shawnb wrote:Actually, just feed the 'value' output of the counter directly into the switch value. It will be ON whenever there is a value & OFF whenever the counter is at 0. If you would like it reversed, use a not(a) module between the counter & the switch.
in my solution you can use only the set input with the counter and reset by hand etc... more options !
Thanks to both Oli_lab and Shawnb. Counter STOP to switch TOOGLE worked. I did it before posting and did not work, I don´t know why... It is a very complex patch, for sure I did something wrong. Could not open your patch since I use USINE STAGE and I get an error message.
