issue loading vst/au on mac
Saynom
Unread post by Saynom » 02 Sep 2016, 18:56
Hi everyone,
I'm very new to Usine but while I was testing I tried to use external plugins and I was stopped by an error.
First, Usine had troubles to recognize my plugins but it eventually find them. But now I can't use any of them (vst and au) and I get an error 015 every time (sometimes followed by a little window with some more errors saying "create procedure failed").
I'm on a 32bits mac but I've always been able to use my plugins in every audio software so I don't understand what seems to be the problem here.
Some help would be greatly appreciated.
Thanks in advance.
Unread post by nay-seven » 02 Sep 2016, 19:21
Hello and welcome saynom,
Here are the E015 error definitions
Impossible to load the AU or VST plugin
* not compatible with you system version
* you try to open a 32bits plug into a Usine 64bits, or inverse
* the plugin doesn’t exists any more in your system
Hope this help
Saynom
Unread post by Saynom » 02 Sep 2016, 19:25
nay-seven wrote:Hello and welcome saynom,
Hope this help
Yep, I saw that, but none of these cases concern me.
Unread post by nay-seven » 02 Sep 2016, 20:23
ok, can you please give me on which OSX you are and example of plug ins you try to run ?
Saynom
Unread post by Saynom » 02 Sep 2016, 21:41
nay-seven wrote:ok, can you please give me on which OSX you are and example of plug ins you try to run ?
I'm on 10.6.8 and my plugins are some basic au(disto/delay/EQ/etc) and GRM tools. They all work fine everywhere else.
Unread post by nay-seven » 02 Sep 2016, 22:16
ok, so i'm afraid i can't test cause, as said on our compatibility page , 10.6 is no longer supported.
but maybe someone else here have still this OS ?
Saynom
Unread post by Saynom » 02 Sep 2016, 22:59
Darn it, I didn't see that... Sensomusic also do that? Every companies drop support on 10.6.8, I thought naively that you weren't one of them... That's sad. :(
If someone else has an idea to fix that it would still be appreciated of course.
Anyway, thanks for your replies Nay-Seven.
Users browsing this forum: No registered users and 116 guests
