microsoft surface 4
peripatitis
Unread post by peripatitis » 23 Aug 2016, 19:42
I am thinking i want to get in this whole touchscreen thing and experiment with it.
So i was wondering has anyone used the sufrace 4 along usine ?
I've seen a couple of reviews for other musical programs which were not very encouraging but some software seemed to cope better than others.
And more generally a suggestion for touchscreen laptops used with usine would be great :)
Vas
Unread post by Vas » 29 Aug 2016, 07:46
My setup includes two vertical monitors and a 23" Viewsonic 10-touch screen.
The touch screen is about 20 degrees off the desk. Made my own stand and
left a small space bellow to be able top store a thin QWERTY keyboard. I can slide
it out like a drawer.
I use the XotoPad 2www.feelyoursound.com/xotopad/. It works great. I am looking
forward to use HH on the touch screen. After all that is the reason why I got HH.
Lately have been doing Photoshop work but I hope by end of the year to get
back to making music and am confident HH will be great on the touch screen.
Windows 10-64bit, i9, 32GB RAM, Studio One 5, Reaper 6, FL Studio 20, Komplete 11,
peripatitis
Unread post by peripatitis » 29 Aug 2016, 09:38
Thanks vas for your input.
How did you end up with the view sonic? Did you try other touchscreen as well?
Vas
Unread post by Vas » 29 Aug 2016, 18:44
I had the 23" Viewsonic TD2340side by side with an Acer 23" and the Viewsonic was a bit better. I have it upside down so the cables run away from me. I have it laying on the desk at 15 (not 20) degrees up.
a few interesting links
http://www.kvraudio.com/forum/viewtopic.php?p=6429912
https://www.kvraudio.com/forum/viewtopi ... 9&t=455677
If you are near Florida you are welcome to come by and check it out.
Users browsing this forum: No registered users and 44 guests
