It would be nifty to have a way to display the number associated with each node of a module in the patch edit view. This would help quickly identify so when scripting or writing IML it is easy to reference.
A hover over the node for a medium time could display the number?
-s
Number of Module Node
- senso
the script need a deep refresh. But dont forget that you can also create links by in/ou name, not only numbers. it can be easier?
CREATE_LINK FADERMODULE "gain" VOLUMEMODULE "gain"
