Grid, bar list and piano roll
Unread post by grego mondo » 05 Aug 2016, 16:46
Hi everybody in there
I'm descovering the grid (I used to sequenced switch and other complicated ways)
I'm working on a song and I need to change the bar list in the middle of a song (to switch between 4/4,4/4 and 6/4,6/4,4/4,4/4,4/4)
So I change my bar list (using different text panels and a selector data controling a Master Sync) when I need to, that's ok
In the same time, I change the pattern of my different piano roll
It works almost fine except :
sometime the first cycle just after I've switch beetween the 4/4 and the 6/4,6/4,4/4,4/4,4/4, it play only the 4 first beats of the pattern then waits until the end of the cycle to restart and play the full pattern.
Hope I'm clear enought to be understood ...
I can send my patch as example but it weight 12 megas :(
Unread post by grego mondo » 06 Aug 2016, 00:05
http://www.sensomusic.com/forums/upload ... 20Good.wkp
Here is the wkp
section 7 it works ok
but section 11 it doesn't : the first cycle piano roll stop after 4 beat and restart playing only at the next start cycle
what am i missing ?
