Problem Mapping XY Korg pad
Jules.W
Unread post by Jules.W » 19 Jun 2016, 17:14
Hi All,
I'm wondering a question...
Each Time I try to map the Xy pad of the Korg NanoPad, Usine don't want to mapp the two different CC value... Only one value is mapped...
I've traced the midi signal until it comes into the modul that I want to mapp.
The Midi trace wrote to me: CC1 when I touch the "x" and CC2 when I touch the "y". All perfect for the moment.
But when I switch in Midimap Mode, I couldn't mapp the two values, only the CC2 value works.
The problem is that both of the two boutons are all mapped in CC2...
I'm not sure that I'm very understandable...
Please let me know if you want more precisions.
Thanks a lot.
Unread post by rlgsbt » 19 Jun 2016, 17:51
Except if you have a program with your hardware to mute/solo datas, you should forget midi learn for XY. Just type the good values in Usine (for example, cc1 for X and CC2 for Y).
Unread post by nay-seven » 19 Jun 2016, 17:53
the solution is to create 2 faders from the x and y inlets of the XY pad,
then to create your midi assignment to these faders
and then set these 2 faders as where=invisible
Users browsing this forum: No registered users and 573 guests
