Is there a specific module for creating random data from physical movement(like balls inside a square)?
Ale
physical engine to control data
Yes, the Draw XY panel and the XY Pad in the modules/interface design.
you can then activate the physics engine in the settings panel/size tab.
Users browsing this forum: Bing [Bot] and 24 guests
