Record gain
uge
Unread post by uge » 15 Jun 2016, 21:47
How can I change the level on the Direct to Disk Panel recordings?
I would like to control the final mix level.
Thanks in advance,
uge
Unread post by nay-seven » 15 Jun 2016, 22:05
You can add a volume patch at the end of each rack ( like the audio thru patch for example)
uge
Unread post by uge » 16 Jun 2016, 20:54
Thanks Nay-Seven,
It's a good solution and it works.
But I was wondering if there any way to have a master channel level for this? I used to recording the Stereo Out.
Thanks again,
uge
