suggestion suggestion
franck
Unread post by franck » 03 Sep 2007, 11:39
Hello Olivier,
What about my most important suggestion ( for me I know ) but I m waiting all days this function for my live set.
My favorite suggestion : a possibility to have "one shot markers" in sequencer use (with loop mode) like I explain you in old message.
My second favorite suggestion :
When creating marker near the begenning or the end of patch it will be interesting if new marker position is at the end or the begenning near patch in the time line ( if Object is selected in the ruler , OBJECT,grid,none).
And the others in my 2007 07 31 post.
Thanks Thanks Thanks Olivier, and sorry for my insistence...
Franck
Unread post by senso » 04 Sep 2007, 09:33
don't worry your suggestions are not dead...
I was aborbed by other important things to do with usine.
I hope soon
franck
Unread post by franck » 04 Sep 2007, 10:29
Thank Olivier,
while waiting is it a solution to create a sub patch to generate a midi message "CONTINUE" so that the Usine sequencer no loop the part between markers ?
franck
Vincent
Unread post by Vincent » 04 Sep 2007, 21:55
Hi Franck
I've made a small patch that manage the sequencer's commands with user curves connected to a Sequencer module.
You could do such a thing with a Loop curve set to 0 and put this small patch between the two markers you don't want to loop?
Do you see the trick?
vincent michel
composer & novelist
Unread post by bsork » 05 Sep 2007, 08:32
Hey Vincent, that was a smart one!
Users browsing this forum: No registered users and 126 guests
