Midi channel
ringmodulator
Unread post by ringmodulator » 23 May 2016, 13:53
I need to send midi from one rack to another with sometimes different message in different channel. But when i use a midi bus ( =create a new midi bus ), strange things happen :
The bus give me the correct Channel that was sent, but always adds the channel 1. So, if i choose to send on ch. 5&6, for example, i will get at the end a message on ch. 5,6,and..1, which i didn't asked for. Is this a kind of bug ? What's the way to fix it ?
Unread post by nay-seven » 23 May 2016, 20:10
Can't reproduce it
Here a basic example working : Download
If this work for you , can you give us a simplified workspace showing the issue ?
ringmodulator
Unread post by ringmodulator » 26 May 2016, 13:49
1/: thanks, but my hh version is too old..can't open your wpk !!.
2/: it seems that the "bug" came from the vst i used (it was edirol orchestra!!).
I ve tried with kontakt, and the midi bus was correctly working.
3/: anyway, it pushed me to do a midi subpatch that can handle with any kind of midi configuration ( like poly timbral instrument with several different midi bus ). And it was the best thing to do. I shouldn't have problem from this side, now.
Unread post by nay-seven » 26 May 2016, 13:54
Glad you found a solution
