Vertical Fader fixes--will they ever happen?
Unread post by woodslanding » 17 May 2016, 08:31
It's still like chasing a greased pig trying to move or resize vertical faders in the IB. And then when I try to wire in the size, I have to set the width to height and vice versa.
Can we get a new vertical fader whose width is an x value, and height is a y value?? Obviously I'm not the only one having a problem with this--the resizing code itself is as confused as I am.
If you need to keep the existing fader for backwards compatibility, I understand..... but please--this has been a problem since HH betas!
Unread post by woodslanding » 17 May 2016, 09:03
In the meantime, if anybody understands it, could you please explain how to use LEFT, TOP, WIDTH, and HEIGHT settings with these faders? I'm utterly confused about what is going on. The values make no sense to me.
Pianoscope
Unread post by Pianoscope » 17 May 2016, 10:22
Would also request proper meters with adjustable scale.. Detailed live work is only possible with precise Metering, allowing control over gain staging, feedback,monitor ring outs, and rms levels, impossible at the moment with Usines Primitive meters. A strange oversight for an app that is designed for live work.
