MIDI performances + reverse inlet + export + mapping list
Unread post by rlgsbt » 16 May 2016, 10:24
I'm working on several workspaces with very different uses and here are some suggestions for HH3 :
- Record midi and automation performances (a kind of event list as text file ?)
- plz, add a "reverse" inlet in the midi sampler.
- It would be nice to export media files used in a workspace in a single folder. It would be usefull for backup and sharing.
... A I'm still interested in a "MIDI, KEY, OSC, BINDS, SMPTE, SYSEX" mapping list
... I am eager to trythe new video module
all the best and many thanks for HH.
Unread post by senso » 17 May 2016, 12:14
hello,
rlgsbt wrote:- Record midi and automation performances (a kind of event list as text file ?)
it's an hard job in a modular context because you can modify a huge list of parameters. but it's still somewhere in my todo list...
you can set the reverse mode individually on each sample, unfortunately not globally,
I'll think about your suggestion.
the "export" command does the job?
implemented in HH3
senso+++
Users browsing this forum: No registered users and 25 guests
