I've tried:
setLength(output, -1);
and
setValue(output, -1);
and both A and B.
And in all cases my outputs are tied....
How can I free them up??
How to create "pass if changed" output in script in HH??
Okay, looks like the problem is when I use an array of tParameter--I'm trying:
[c]
for i := 0 to SEND_COUNT-1
do begin
setLength(OUTs,-1);
setValue(OUTs, -1);
end; [/c]
And just getting zeroes on output.
Regular tParameters work.
[c]
do begin
setLength(OUTs,-1);
setValue(OUTs, -1);
end; [/c]
drakh
for the array as output parameter use this
for i:=0 to some_number
do begin
SetDataArrayValue(your_output_data_array,i,element_value);
end;
SetLength(output_data_array,some number); //you dont need to do this after setting each value, doing it after you end the iteration is fine
if you want just send "empty array" SetLength(output_data_array,0);
do begin
end;
I figured it out. I thought I had tried every combination, but I had not. This is what worked. The outputs still show 0, but they are red, and the switches they are connected to can be turned on and off by the user.
[c] for i := 0 to SEND_COUNT-1
do begin
setLength(OUTs,-1);
//setValue(OUTs, -1); // undoes the previous code!!
end; [/c]
Maybe this will help someone someday (maybe me
do begin
setLength(OUTs,-1);
end; [/c]
